william Offline
#1 Posted : Thursday, 4 May 2023 9:03:06 PM(UTC)
william
Hello, decided to dust the cobwebs off the car awhile back and have been tackling a brake issue ever since, its a HK Holden brougham 307, disc/drum, ive replaced the brakelines,master cylinder, v8 booster, and calibers. after bleeding all 4 corners both the fronts dont seem to be applying the brakes unless you pump the peddle afew times, have bled the car about 6 times now with no luck. any help would be appreciated.
8D11PCH2 Offline
#2 Posted : Thursday, 4 May 2023 11:25:14 PM(UTC)
8D11PCH2
Was thanked: 23 time(s) in 22 post(s)
Did you install the calipers so the bleeder nipples are at the top?
#3 Posted : Friday, 5 May 2023 8:01:52 AM(UTC)
A quick & easy check is to clamp off the 2 front hoses & see if the pedal improves markedly.
If it does, 8D11PCH2 is on the money.
william Offline
#4 Posted : Friday, 5 May 2023 12:28:40 PM(UTC)
william
i believe the nipples are on the bottom ill have to double check when i get home
william Offline
#5 Posted : Friday, 5 May 2023 6:26:08 PM(UTC)
william
well both the nipples are on the bottom, will try switching them to top idk how the lines are meant to get moved but will give it a go, does anyone know where i can fond a picture of how these calipers are meant to be? should of taken pictures before we pulled it apart
KBM Offline
#6 Posted : Friday, 5 May 2023 6:44:31 PM(UTC)
KBM
Just swap them left and right.
 1 user thanked KBM for this useful post.
Smitty2 on 5/05/2023(UTC)
This page was generated in 0.099 seconds.
