Hello, decided to dust the cobwebs off the car awhile back and have been tackling a brake issue ever since, its a HK Holden brougham 307, disc/drum, ive replaced the brakelines,master cylinder, v8 booster, and calibers. after bleeding all 4 corners both the fronts dont seem to be applying the brakes unless you pump the peddle afew times, have bled the car about 6 times now with no luck. any help would be appreciated.
Joined: 11/09/2016(UTC) Posts: 209 Location: OZ Was thanked: 23 time(s) in 22 post(s)
Did you install the calipers so the bleeder nipples are at the top?
A quick & easy check is to clamp off the 2 front hoses & see if the pedal improves markedly.
If it does, 8D11PCH2 is on the money.
Dr Terry |
i believe the nipples are on the bottom ill have to double check when i get home
well both the nipples are on the bottom, will try switching them to top idk how the lines are meant to get moved but will give it a go, does anyone know where i can fond a picture of how these calipers are meant to be? should of taken pictures before we pulled it apart
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
Just swap them left and right.
1 user thanked KBM for this useful post.
