Torana1978 Offline
#1 Posted : Friday, 1 September 2023 7:27:29 AM(UTC)
Torana1978
Russian Federation
VR Ute's brochure says it's first Australia's commercial vehicle with an airbag. It is correct? Unfortunately, there are no details. I'm assuming the airbag was an option only for Ute S. But maybe for base too.
#2 Posted : Friday, 1 September 2023 7:56:34 AM(UTC)
Yes, I do believe that the VR Ute was the first Australian commercial with an airbag. The VS was likewise the first Aussie commercial to offer an airbag for both driver & passenger.
You are correct about the availability, brochure details are very sketchy, with lines like "the airbag is an option on certain models". My thoughts are that it was an option on both the base (A9K) Ute & the S Ute, but not with a column shift auto, because of the complexities involving the combination of the airbag clock spring & the shifter.
 2 users thanked Dr Terry for this useful post.
Smitty2 on 1/09/2023(UTC), Torana1978 on 2/09/2023(UTC)
Torana1978 Offline
#3 Posted : Saturday, 2 September 2023 12:47:41 AM(UTC)
Torana1978
Russian Federation
Thanks. For some reason there are no factory options in the brochure, only dealer options. It is clear that the airbag was from factory and therefore is not on the equipment list.
#4 Posted : Saturday, 2 September 2023 8:57:00 AM(UTC)
Yes the brochure is very odd in that regard.
There is no "equipment" list as such, but has a "features" list & it says at the bottom of the page to "see your Holden Dealer about Air Conditioning, 5 Litre 165 kW V8 Engine, 4-speed Automatic, LSD, Alloy Wheels, Metallic Paint, Auto Column shift, Seat Trim Style, Bench / Bucket Seating, SRS (Airbag), Rubber Flooring etc. etc" All of these are quite clearly factory options.
Torana1978 Offline
#5 Posted : Saturday, 2 September 2023 10:24:22 AM(UTC)
Torana1978
Russian Federation
The brochure also states that 5.0 185kW (XX1, probably) is available. Perhaps a mistake? I thought the XX1 was offered only for VR Commodore/Calais sedans with IRS.
Edited by user Saturday, 2 September 2023 10:27:18 AM(UTC)  | Reason: Not specified
#6 Posted : Sunday, 3 September 2023 11:50:14 AM(UTC)
I know of 2 VR wagons with the 185 kW motor, so that might not be the case.
stevo Offline
#7 Posted : Sunday, 3 September 2023 1:12:21 PM(UTC)
stevo
Did they ever make any VR utes with SRS? There wouldn't be many if any at all.
Hay Politician theres a yank over there go suck it off you gave it everything else it took our money and fucked off.
#8 Posted : Sunday, 3 September 2023 3:29:22 PM(UTC)
VN, VQ, VG and VP were available as HSV enhanced with the (external) mods to make 180kW. By the time VS came around it was called HBD (Holden by design) and you could get the 185kW engine, again it was all external stuff. In VSIII the 195kW engine was available as a HBD option, not sure if this was a different engine like the 195kW was in VT or if it was the same engine with external mods. Not certain if VR was still HSV enhanced or HBD.
#9 Posted : Sunday, 3 September 2023 6:36:18 PM(UTC)
Was thanked: 27 time(s) in 27 post(s)
ummm.. nope
I had VR Berlina sedan... 5.0 manual and solid axle (LSD of course) with the 185i option
Std steering wheel with no airbag
Thing even had a HSV plate on it if I recall correctly
Shearer Offline
#10 Posted : Sunday, 10 September 2023 10:48:36 AM(UTC)
Shearer
Hi,
I know VS utes with column auto did have Driver's side as I company I worked for once had one; but no passenger's airbag.
I would be interested if VR utes (including sedans and wagons) with column shift had airbag option; early VR Column Shift autos used an unusual set-up with the wiper switch on the dash where the speed alert would be located and a black VP Calais steering wheel. This set-up was changed during the VR production with the wiper stalk next the column shift and a VR steering wheel.
#11 Posted : Monday, 11 September 2023 3:42:22 PM(UTC)
Originally Posted by: Shearer Go to Quoted Post
Hi,
Yes the VS ute could be ordered with either RH airbag only or both airbags as an option. There is no stipulation in the brochure such "available on certain models". All VS utes had 4-spoke steering wheels as well, where as stock VR utes had 3-spoke.
Hi,
This makes sense & supports my theory that the column auto caused issues in early VR utes. I remember the change to the wiper switch mid-VR, obviously this was enable the fitting of airbags to those cars.
This page was generated in 0.245 seconds.
