holden05 Offline
#1 Posted : Sunday, 3 September 2023 7:27:03 PM(UTC)
holden05
Just changed the holden rodeo v6 3.6
Used penrite 5w40
Was in a bit of a hurry adding oil and it looks like I’ve overfill by approx 250-300ml. Is it worthwhile draining some or not worth the hassle?
#2 Posted : Monday, 4 September 2023 8:14:25 AM(UTC)
Was thanked: 34 time(s) in 33 post(s)
I wouldn't think that much over will matter, should be only 5mm or so above the full mark on the dipstick? If it's much more than that I would drop some oil to avoid your crank churning in it.
holden05 Offline
#3 Posted : Monday, 4 September 2023 1:44:15 PM(UTC)
holden05
Yep, from memory 5-10mm or so above sounds about right. There was about 250ml left in the 7 litre bottle
Edited by user Monday, 4 September 2023 1:46:36 PM(UTC)  | Reason: Not specified
