Just changed the holden rodeo v6 3.6 Used penrite 5w40 Was in a bit of a hurry adding oil and it looks like I’ve overfill by approx 250-300ml. Is it worthwhile draining some or not worth the hassle?
Thanks: 3 times Was thanked: 34 time(s) in 33 post(s)
I wouldn't think that much over will matter, should be only 5mm or so above the full mark on the dipstick? If it's much more than that I would drop some oil to avoid your crank churning in it.
Yep, from memory 5-10mm or so above sounds about right. There was about 250ml left in the 7 litre bottle Edited by user Monday, 4 September 2023 1:46:36 PM(UTC)
| Reason: Not specified
