Joined: 6/09/2023(UTC) Posts: 7 Location: Fraser coast Thanks: 6 times
Is there much difference in size between H series buckets and LX LH Torana bucket seats,also would the Torana buckets bolt straight into the factory bolt holes in a one tonner…….Thanks all.
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
They are different between HD and HQ. HK-HG are pretty much the same. HD-HR will interchange. HQ is totally different. Not sure about LH-LX into HQ, they are similar seats but the rails might be different. HQ is interchangeable with other W series ie HJ to HZ. WB is different as the rails are closer together on bucket seats. |
Bucket seats from EJ will interchange up to HG. HQ on are different. W sized cars (HQ-WB) seats are similar but wider than LH-UC, but are close enough to be modified to fit.
Dr Terry |
Joined: 30/04/2005(UTC) Posts: 463 Was thanked: 14 time(s) in 13 post(s)
Thinking back, Lh-LX buckets were same bolt holes as HQ , but Torana floor must be different shape as we had to put spacers at the front to make the seat even . Long time ago since i did this . Thanks Mark. |
life is good in "Wine & Holden Marlborough " |
