Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Is there a sealant that used underneath these before they are screwed down on the sills?
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Old memory from pulling these off back in the early 80’s but I think they used to have a sealant around the screw threads to prevent rust formation. |
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Originally Posted by: HK1837 Old memory from pulling these off back in the early 80’s but I think they used to have a sealant around the screw threads to prevent rust formation. yup.. correcto in the case of both holden and Torana car lines, grey body sealant gets applied on the holes in the sills to prevent rust (V car gets clip on scuff floor plates - no holes in sills) |
What product would you recommend? After something that stays soft but is waterproof and doesn’t permanently stick the place to the sill
Sounds like drip check. Sorta like chewing gum out of the tube. https://au.jbtools.com/3...dmwqaO7RUAhoC0NkQAvD_BwE |
