Joined: 28/05/2016(UTC) Posts: 38 Location: Sydney Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Is there a documented process on how to remove and replace the two dowel pins on either side of the rear of the block?
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Why remove them? I imagine you’d drift them from behind. The only time I’ve ever seen them removed is when blocks are redrilled (see image in attached link) http://www.gumtree.com.a...ocial&utm_source=sms |
I need to put in longer ones to accommodate an adaptor plate. All the instructions have is "Remove original engine dowels". https://malwoodauto.com....ions-t56-vn-vp-vr-vs-v8/
You can get a dowel removal kit which I have seen work.
For anyone else looking to do the same... Find a G clamp and ring (I used the one from a ball joint remover set) plus a 2 inch long 3/8 bolt. Put the bolt in the hole behind the dowel pin, put the ring around the protruding dowel, and screw the clamp tight around both. The dowel will push out.
1 user thanked tidyVan for this useful post.
