Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
Saw this on FB Marketplace. No association with it. Chassis number matches the comp plate. Can understand swapping the front sheetmetal, but the full interior looks late HX to me. Thoughts? https://www.facebook.com...ral_story_type=top_picks |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
It's a HX wagon body with HQ tags. The rail number has been stamped into the HX rails I think - you can still see the remnants of the old number. Engine number is dodgy too, it is a VK 304 number. |
Originally Posted by: HK1837 It's a HX wagon body with HQ tags. The rail number has been stamped into the HX rails I think - you can still see the remnants of the old number. Engine number is dodgy too, it is a VK 304 number. I did see the old chassis number, wondered if it was a factory mistake. |
Thanks: 2 times Was thanked: 28 time(s) in 27 post(s)
Probably an old rebirth from the 80s.
