Taztiger4 Offline
#1 Posted : Sunday, 14 January 2024 11:19:00 AM(UTC)
Taztiger4
Hi all
Looking for a steering column for my 10/74 HJ Col auto 253 1 Tonner (mine presently has later column with ind, dip, wipers on stalk & want to go back to original)
What are the difference between a HQ & HJ column please
IS there a source of replacement / recond columns anywhere ?
Thanks in advance
#2 Posted : Sunday, 14 January 2024 11:37:20 AM(UTC)
You can use a HX-HZ column, even WB. You just have to replace the part with the keys switch in it with a HQ or HJ one.
Or you can use a HQ column, just replace the plastic piece that matches the dash with a HJ-WB one to suit the column (as in to suit if its column shift or floor/console shift).
You'll need a floor high beam switch and find the harness piece to plug it into. If it s a HJ body it should have the holes to attach the switch to.
Best bet is leave the column that is there now if its OK and just replace the top cast alloy bit.
This bit:
https://www.ebay.com.au/...D%7Ctkp%3ABk9SR96c3dmgYw
Or buy a whole column if yours is shagged, like this:
Taztiger4 on 14/01/2024(UTC)
Taztiger4 Offline
#3 Posted : Sunday, 14 January 2024 11:42:10 AM(UTC)
Taztiger4
sensational , thanks very much & I just bought that top bit you linked to :)
#4 Posted : Sunday, 14 January 2024 11:57:22 AM(UTC)
You'll need the indicator mech and an indicator stalk too. Plus maybe a key barrel depending upon what type is on the later column you have.
Taztiger4 Offline
#5 Posted : Sunday, 14 January 2024 12:01:23 PM(UTC)
Taztiger4
thanks again, yes I was about to ask about the indicator assembly
Mine does have the 2 holes for the dip switch & I have sourced a switch & plug already
Edited by user Sunday, 14 January 2024 12:02:22 PM(UTC)  | Reason: Not specified
This page was generated in 0.158 seconds.
