Joined: 15/09/2022(UTC) Posts: 73 Location: Perth Thanks: 33 times
Hi all
Looking for a steering column for my 10/74 HJ Col auto 253 1 Tonner (mine presently has later column with ind, dip, wipers on stalk & want to go back to original)
What are the difference between a HQ & HJ column please
IS there a source of replacement / recond columns anywhere ?
Thanks in advance
You can use a HX-HZ column, even WB. You just have to replace the part with the keys switch in it with a HQ or HJ one. Or you can use a HQ column, just replace the plastic piece that matches the dash with a HJ-WB one to suit the column (as in to suit if its column shift or floor/console shift). You'll need a floor high beam switch and find the harness piece to plug it into. If it s a HJ body it should have the holes to attach the switch to. Best bet is leave the column that is there now if its OK and just replace the top cast alloy bit. This bit: https://www.ebay.com.au/...D%7Ctkp%3ABk9SR96c3dmgYwOr buy a whole column if yours is shagged, like this: https://www.ebay.com.au/...D%7Ctkp%3ABk9SR96c3dmgYw |
sensational , thanks very much & I just bought that top bit you linked to :)
You'll need the indicator mech and an indicator stalk too. Plus maybe a key barrel depending upon what type is on the later column you have. |
thanks again, yes I was about to ask about the indicator assembly Mine does have the 2 holes for the dip switch & I have sourced a switch & plug already Edited by user Sunday, 14 January 2024 12:02:22 PM(UTC)
| Reason: Not specified
