Fastlane
Holden Forums
Holden Technical Talk
Accelerator Return Spring bracket
Joined: 15/09/2022(UTC) Posts: 73 Location: Perth Thanks: 33 times
Hi Can someone please confirm the correct return spring bracket to fit this manifold Think its from a HX cheers
Joined: 28/05/2016(UTC) Posts: 38 Location: Sydney Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Is this what you are looking for? Item 7.
Thats great thankyou, gives me an idea on what to look for & also answers what would have been my next question re the coil mounting & location
Thanks: 1 times Was thanked: 487 time(s) in 464 post(s)
That isn't the coil. It's the pollution switch that turns vacuum advance on and off. |
Oh , thanks, learning every day !
Originally Posted by: HK1837 That isn't the coil. It's the pollution switch that turns vacuum advance on and off. I assumed obv incorrectly that this coil bracket would be correct & the little tit on the back looks to be in the right spot even to line up with the notch in the casting Mine doesnt have that pollution switch anywhere
This should help.
1 user thanked tidyVan for this useful post.
Fastlane
Holden Forums
