tidyVan Offline
#1 Posted : Wednesday, 24 January 2024 8:06:56 PM(UTC)
tidyVan
What is inside the canister?
All of the exploded parts views I have show nothing inside.
Canister exploded view
Smitty2 Online
#2 Posted : Wednesday, 24 January 2024 8:27:47 PM(UTC)
Was thanked: 27 time(s) in 27 post(s)
proper technical name is .. charcoal canister so the answere is 'activated charcoal'
why?
the charcoal-filled canister's job is to absorb fuel vapor from the fuel system that would otherwise vent out to the atmosphere,
causing pollution. Vapors trapped by the charcoal are released back into the engine through a purge style valve and then burned in the engine
HTH
#3 Posted : Wednesday, 24 January 2024 8:29:35 PM(UTC)
Charcoal. Google it, example:
https://www.carparts.com...a-vapor-canister-do/amp/
Note it’s not part of ADR27A, nor ADR27. Was mandated from 1/1/75 independent of the introduction of both.
Edited by user Wednesday, 24 January 2024 8:31:45 PM(UTC)  | Reason: Not specified
tidyVan Offline
#4 Posted : Wednesday, 24 January 2024 8:52:54 PM(UTC)
tidyVan
Thank you both for the replies. :-)
I remember it being called a charcoal canister so was expecting to see an indication of such on the diagrams.
Try as I might with Google I can't find what the inside looks like. Does the charcoal ever lose effectiveness and need to be replaced?
