Joined: 21/12/2018(UTC) Posts: 85 Location: SA Thanks: 22 times Was thanked: 9 time(s) in 9 post(s)
I had a quick look because the tonner was protesting whenever I went up a hill. Anything other than very slight throttle pressure on an upslope brings on a heap of pinging. Seems like the vacuum advance isn't working. I sucked on the hose while it was idling and this gave no change in the timing. Definitely getting vacuum from the carb, up to 15mm Hg when I blip the throttle. What goes wrong with them. Holed, full of crap, seized? Is there an easy fix? TIA. Edited by user Sunday, 28 January 2024 8:30:37 PM(UTC)
| Reason: Not specified
Thanks: 1 times Was thanked: 487 time(s) in 464 post(s)
They are just a rubber diaphragm. It’s probably shagged. |
