hilta Offline
#1 Posted : Friday, 29 March 2024 12:22:17 AM(UTC)
hilta
Late Hz Wb v8 full cable pull type clutch, is the top cable mount bracket the same on both 6 and 8 cylinder? I have the correct pedal but not sure I have the correct bracket the cable goes through. Also does the pedal need a return spring and if it does has anyone got the spring they would sell? Thanks in advance
#2 Posted : Friday, 29 March 2024 9:40:34 AM(UTC)
Bracket is the same, it has the two pivot holes in it for the clutch pedal pivot. Top hole is for a 6cyl car and only about 8/78 HZ onwards have that second pivot hole. The bottom hole is for the V8 pedal and you can use it in any HQ-HZ without the top pivot hole.
The return spring is inside the pedal pivot, held there by the bushes. See the one here:
https://www.ebay.com.au/...D%7Ctkp%3ABk9SR_yR2_bQYw
Someone was selling repro pedals, they may sell the springs too. I think the 6cyl pedal uses the same spring. Maybe ask them what they did for the spring:
https://www.kingswoodcou...sion-kit-hq-h/KPedalV8-1
Here is a cheaper one that has the spring and the cable support if you are missing that, This is a 6cyl pedal though:
https://www.ebay.com.au/...D%7Ctkp%3ABk9SR6r6__bQYw
9945732, 6cyl and V8 springs are the same part number.
Edited by user Friday, 29 March 2024 9:46:05 AM(UTC)  | Reason: Not specified
hilta Offline
#3 Posted : Friday, 29 March 2024 5:26:53 PM(UTC)
hilta
Thank you
