trubluhq Offline
#1 Posted : Thursday, 24 September 2009 9:32:58 PM(UTC)
trubluhq
Hi All,
Just trying to work out whether the HQ 253 actually needs a timing chanin damper/tensioner on not.
Apparently later model 308s ie VBs dont have them at all. CROW CAMS say the V8s dont need them.
Whats the answer ? Put one back in, if I can get one, or just fit the CROW kit with not tensioner ? My last one was cut to pieces...probably the 1974 original.
Thanks in advance John
trubluhq Offline
#2 Posted : Thursday, 24 September 2009 9:42:26 PM(UTC)
trubluhq
I may have found an answer...HQs had em, by HZ they were gone. The old part of 7436226 isnt on GMH parts base anymore either.
andrew stephenson Offline
#3 Posted : Thursday, 29 December 2011 3:44:02 PM(UTC)
andrew stephenson
I TO HAVE THE SAME PROBLEM, WHEAR CAN I GET A TIMING GUIDE FOR MY 308 AS THE ONE IN IT HAS COME APART. I WOULD LIKE TO PUT ONE BACK IN IT.
ALSO THE CAMSHAFT HAS INDEX MARKS ON IT , IT SEEMS TO BE SET AT +8 DEGREES WHEAR SHOULD IT BE SET FOR NORMAL STREET USE.THIS ENGINE WAS BUILT AS A DRAG ENGINE, BUT I AM PUTTING IT INTO MY HZ 2 TONE FOR STREET USE ONLY. SORRY FOR SPELLING,
ANDREW STEPHENSON
[email protected]
KeithA Offline
#4 Posted : Thursday, 29 December 2011 8:21:05 PM(UTC)
KeithA
You don't have drag use, street use settings on the timing gear for camshafts. The 8 degrees is where the camshaft was dialed into for best performance. You can't set it at 0 degrees thinking that is for street use and expect it to work as designed and deliver power. Leave it alone, or buy another cam and lifters with a milder grind and install. Remember though, you should still dial in any cam that has a grind other than standard.
the eh Offline
#5 Posted : Friday, 30 December 2011 5:34:30 PM(UTC)
the eh
I have never used a tensioner/damper. When Holden were using a 3SR62 (62 link single row chain) it may have been needed to help compensate for the excess wear. With a double row 3DR62 chain there is no need. Remember metallurgy and manufacturing technology have come a long way in 40 years.
PS the Holden V8 3DR62 chain is the same as the Toyota 18R series motors. If you get stuck there's an alternative.
This page was generated in 0.088 seconds.
