superstock Offline
#1 Posted : Monday, 1 November 2010 7:22:04 AM(UTC)
superstock
Hi all just rebuilt 186 & when I went to fit cam would not fit. had a look no box & it said STD. So to make sure took out front & back bearings & they have STD stamped on them. Bearings will slip over bearing on cam very good fit. Inserted cam bearing in block & it,s just to tight.Thinking about using 800 or 1000 wet& dry & remove 1.5 thou. Cam has been in my old 192 & it has STD bearings very good fit.Has anyone else had this problem. Cheers wayne.PS by the way you have a very good forum.
adam PERTH Offline
#2 Posted : Saturday, 6 November 2010 7:36:28 AM(UTC)
adam PERTH
maybe your block has a slight warp.
Tuning for Holley carbs in Perth? PM me.
