disowned Offline
#1 Posted : Sunday, 7 November 2010 7:30:24 AM(UTC)
disowned
hey all anyone got any ideas bout how to install a taco with a haltech ecu
greenhj Offline
#2 Posted : Monday, 8 November 2010 1:07:01 AM(UTC)
greenhj
Was thanked: 12 time(s) in 10 post(s)
try not to drip mexican hot sauce into the ecu.
11.38@117mph
will go quicker
11.34@121mph
went quicker and faster, just not quick enough.
now being rebuilt with less cam, much less comp, and a turbo.
#3 Posted : Monday, 8 November 2010 3:37:41 AM(UTC)
You beat me to it. I was thinking a beef taco, with chilli sauce.
80569K Offline
#4 Posted : Monday, 8 November 2010 4:15:07 PM(UTC)
80569K
C'mon chaps, don't be nasty. Years ago some fool decided to stuff our education system by allowing phonetic spelling, we have to live with the results.
#5 Posted : Monday, 8 November 2010 4:40:50 PM(UTC)
Sorry, I couldn't resist.
I think it would depend on with version of ECU you have, but most aftermarket units have a dedicated tacho output pin.
#6 Posted : Monday, 8 November 2010 5:27:24 PM(UTC)
What model Haltech?
If it's the E6-GM then you can use the standard factory take-off point to drive a tacho.
But then again, what model car are we talking, and what motor is in it, as the Haltech on a V6 is very different to the V8 when it comes to driving the tacho.
disowned Offline
#7 Posted : Monday, 8 November 2010 9:34:30 PM(UTC)
disowned
hey all sorry for my poor spelling skills. My haltech is a E6K i have a HZ tonner with a Injected 5L from a VS.
#8 Posted : Monday, 8 November 2010 9:56:23 PM(UTC)
In that case, as long as your original tacho is a negative pulse unit, you can run your tacho off the negative terminal of the coil, just like it would have been before. This is how all VN-VS 5L Commodore tachos are hooked up (they simply share that circuit).
greenhj Offline
#9 Posted : Tuesday, 9 November 2010 1:20:02 AM(UTC)
greenhj
I wasnt maliciously busting your chops about spelling, my reply was just the first thought i had when i read the thread title and opened the topic.
At least one other person was thinking it too so that makes it ok lol.
good luck getting it sorted, doesnt sound like a big deal given the advice youve received.
phill
11.38@117mph
will go quicker
11.34@121mph
Edited by user Tuesday, 9 November 2010 1:30:38 AM(UTC)  | Reason: Not specified
jabba Offline
#10 Posted : Tuesday, 9 November 2010 7:12:53 AM(UTC)
jabba
As a check, take the wire that you think should feed the tacho, and earth it while the engine is running. If it is the right wire, the engine will cut out.
#11 Posted : Tuesday, 9 November 2010 7:21:47 AM(UTC)
or hook the tacho up and see if it works?
disowned Offline
#12 Posted : Tuesday, 9 November 2010 9:36:29 AM(UTC)
disowned
Thanks all big help. No sweat greenhj all fun and games till someone gets mexican hot sauce in the eye
This page was generated in 0.100 seconds.
