Hey i am having some starting issues with my 98 VT V8 berlina. It fires fine when cold but if i go for a drive , have a quick stop and then go to start again it will turn over and about half the time not fire. I can get around this by turning the ignition on for 5 or so seconds before firing with a little throttle. I took it to my dealer and they found that the coolant temp sensor had a dodgy voltage so i am changing that. They also checked the fuel pressure and it was sweet. I am thinking its electrical and i am aware of the memcal fault that can occur when leaving the keys in the ignition when stopped, any ideas?
does it blow black smoke on hot startup? probably coolant sensor.
Tuning for Holley carbs in Perth? PM me. |
A guy at work had a similar prob with a VT v6 sometimes it would start and not other times ,it turned out to be a dodgy connection with the plug to the coil pack.
as above ^^
check the simple things like the battery terminals are tight, the earth lead is tight, and all other electrical connections are tight and clean
