#1 Posted : Sunday, 5 September 2004 9:38:56 PM(UTC)
302 closed chamber heads, Single spings with a dampener (good for up to 5800rpm on a hydraulic camshaft, 120-130lb closed and 330lb open), inlets ports appear to be stock, exhaust ports look like they've had a very slight clean up, Valves are stock 2V, I quickly CC'd the heads the chambers are 60cc no more than 62cc, valvestem seals are good. These do not require a rebuild. They can be bolted on and ran. $300ono
<p>
See here for picture :
<p>
<a href="http://home.iprimus.com.au/bwill/xb_wrecking/">http://home.iprimus.com.au/bwill/xb_wrecking/</a>
<p>
Located in Cranbourne, Vic. Contact : [email protected] or 0417-148-093
<p>
