hjking Offline
#1 Posted : Wednesday, 13 April 2011 6:46:25 AM(UTC)
hjking
The brake warning light has come on and stayed on in my HJ.
I checked the switch on the handbrake and it looks ok. I disconnected the wire from the proportioning valve and the light went out!
The brakes seem to stop ok. Does anyone know what is going on?
#2 Posted : Wednesday, 13 April 2011 7:01:20 AM(UTC)
hi Peter,check brake fluid,replace switch,bleed brakes and get back too us...lol....true!
#3 Posted : Thursday, 14 April 2011 6:55:06 AM(UTC)
You have or have had a pressure differential between your front and rear brake circuits as Jim said.
To reset the switch unplug the wires then unscrew the switch completely then re fit it.
I would strongly advise bleeding you brakes though as those switches don't trigger for no reason.
hjking Offline
#4 Posted : Friday, 15 April 2011 5:15:06 AM(UTC)
hjking
Do you think the switch might be faulty or stuck? The car is only used for short trips once a week.
#5 Posted : Friday, 15 April 2011 5:26:42 AM(UTC)
Might be "shorter" than you think.faulty / stuck go back to the first answer...sorry no short cuts here.
#6 Posted : Friday, 15 April 2011 10:40:16 PM(UTC)
The switchtes rarely go faulty.
If you REALLY think that there is not a problem with your brakes just reset the swich as I described above and take the chance. If it triggers the next time you use the brakes then you are in for a brake bleed.
You will be in for at least a brake bleed as it will trigger again.
hjking Offline
#7 Posted : Saturday, 16 April 2011 4:05:23 AM(UTC)
hjking
So to reset the switch I just remove it and place it back in again or is there someting else I need to do with it?
