xbro87 Offline
#1 Posted : Saturday, 30 April 2011 8:43:02 AM(UTC)
xbro87
Hi all been quite awhile since ive been on here, but know that someone will be able to help. My plates read as follows can you plz tell me what Ive got.
chassis # BHJ61381A
engine # HR47008
molel # HJ8WQ69
body # 196278/A
trim # 1890/60Y
paint # 568/15953
engine L32
trans # M20
rraxel # GU4
the restoration is about to get underway and I want to make sure I get it right.
Thanks guys
JBM Offline
#2 Posted : Saturday, 30 April 2011 9:11:16 AM(UTC)
JBM
Chassis is Adelaide built HJ.
HR... is 253.
Model is HJ Full size Kingswood sedan.
Body is Adelaide.
Trim is Chamois.
Paint is Mandarin Red.
Eng 253
Trans wide ratio aussie 4 speed
Diff is 2.78:1.
James
#3 Posted : Saturday, 30 April 2011 4:03:38 PM(UTC)
engine # HR47008 = an LH Torana 4.2 V8
molel # HJ8WQ69 = an HJ 4-door GTS Monaro
60Y = Chamios trim with cloth insert
Mr.Jones Offline
#4 Posted : Saturday, 30 April 2011 8:38:44 PM(UTC)
Mr.Jones
Whats the vin for your Monaro? Is it 5/76 or 6/76? It's the last Adel HJ body no. I have recorded by a couple of thou, it may have been one of the last batch. Does it have many options? Correct engine no. should be around QR750000
Leroy
Edited by user Saturday, 30 April 2011 8:41:23 PM(UTC)  | Reason: Not specified
Voltaire
xbro87 Offline
#5 Posted : Sunday, 1 May 2011 6:38:00 AM(UTC)
xbro87
thanks heaps i knew i could count on you all.
Leroy it is 06/76 but its not the original engine i knew that.
not sure what is considered options?
I also brought a HZ prem (253)to change the rails so as to have rts for better handling, have also taken the aircon from the hz because the monaro had none, seats and doors will also be changed. I am having the hz motor reconed with a mild cam, 4 barrel carby, electronic ignition and anything else that my budget allows as we get to it (engine wise)
Is there anyway to tell how close to the end of the run it was built.
Thats a cool fact to find out cause i brought the car in Tassie but live in adelaide its like bringing him home.
This page was generated in 0.097 seconds.
