deputy Offline
#1 Posted : Monday, 16 May 2011 8:37:45 PM(UTC)
deputy
Can anyone help with a problem. There is a bit of play both up/down and side to side with the steering wheel in my HR. I have just had the steering box replaced with a new one and was wanting to correct this movement. Its the main shaft with splines the steering wheel fits on that is moveing. Is there a bush that can be replaced that will fix the movement or is it somthing more?
Any help appreciated. Anthony
#2 Posted : Tuesday, 17 May 2011 9:27:28 PM(UTC)
Check behind the steering wheel to see if the spring is present.
The upper column bearing in these cars rarely 'wears out'. The shaft is centred by a tapered ring, held in place by the spring. If the spring (or tapered ring) is missing then the shaft will be loose in the bearing & give the result you have.
deputy Offline
#3 Posted : Tuesday, 17 May 2011 10:22:47 PM(UTC)
deputy
Thanks Dr Terry.
Ive just checked and the spring is missing. If I put a little pressure on the bearing the movement stops. I just need to find a spring. Is it a certain one or will I be able to use a generic one that fits, any ideas?? And thanks again.
Anthony
#4 Posted : Wednesday, 18 May 2011 2:55:16 AM(UTC)
An original one would be more desirable, but a generic one of the right size & tension would be OK.
deputy Offline
#5 Posted : Monday, 23 May 2011 9:38:14 PM(UTC)
deputy
Thanks again,
Ill start looking for an original one first.
Anthony
