brahman Offline
#1 Posted : Saturday, 28 May 2011 12:08:32 PM(UTC)
brahman
I have an Equipe, After changing the battery in both keys one of the keys does not start the car, yellow light blinks. Can open the doors manually and remotes in the keys does not work
waiting for a solution please hhhhellllp
bm
blt76 Offline
#2 Posted : Saturday, 28 May 2011 5:30:52 PM(UTC)
blt76
you have probably lost the transponder out of the key
it is a small black rectangular plastic piece that sits in a slot inside of the key
#3 Posted : Saturday, 28 May 2011 6:36:27 PM(UTC)
Yes, I've seen this many times. Take time to have a look on the floor near where you changed the battery. The transponder chip looks like nothing more than a small broken chip of black plastic. They can easily fall out when you slide the remote section out of the key head.
The remote bit only operates the central locking. The car can be started & driven with the key blade alone, as long as the little transponder chip is attached.
brahman Offline
#4 Posted : Monday, 30 May 2011 10:30:54 PM(UTC)
brahman
Thanks friends
will look into it thanks for your time and answers highly appreciated
bm
brahman Offline
#5 Posted : Tuesday, 31 May 2011 3:25:28 AM(UTC)
brahman
If I have lost this transponder, is there a way I can get another one from somewhere?
Thanks for the replies
bm
