mick_sandman Offline
#1 Posted : Monday, 30 May 2011 6:34:27 AM(UTC)
mick_sandman
Hi, please are the heads off vk 308 ok to use on hj 308??(not sure if they are pre polution) Thanks for the help. hj is a blue motor.
JBM Offline
#2 Posted : Monday, 30 May 2011 6:40:45 AM(UTC)
JBM
The VK heads will have a different shape EGR port and bolt pattern but will bolt up to the early block. The manifolds are also different so need to match the heads you use.
James
micks_sandman Offline
#3 Posted : Monday, 30 May 2011 6:56:43 AM(UTC)
micks_sandman
Thanks James, its always good to ask before buying, appreciate the help.
#4 Posted : Monday, 30 May 2011 5:43:40 PM(UTC)
You say the hj has a blue motor. Black heads are similar as blue arent they?
Edited by user Monday, 30 May 2011 6:21:45 PM(UTC)  | Reason: Not specified
castellan Offline
#5 Posted : Tuesday, 31 May 2011 1:27:44 AM(UTC)
castellan
What is the engine number on the block.
What intake have you got is it u shaped or square or none
This page was generated in 0.111 seconds.
