#1 Posted : Sunday, 19 June 2011 10:58:33 AM(UTC)
On the Vr auto radiator on the passenger side about 3" down the side there is a water pipe/rubber pipe coming off,esume it is to the oil cooler or transmission.
mine has sprung a leak, it is not coming from the pipe or rubber hose, it is coming from the joint whre the fitting goes into the radiator.
The fitting is a 19mm or so nut, does it actually screw in so a gasket can be fitted or is it a soldered fitting?
thanks
#2 Posted : Sunday, 19 June 2011 8:01:51 PM(UTC)
the tanks are plastic, there is brass fittings in the plastic with barbs that screw in for the lines
the radiators are very cheap new, i got 1 for $89 with free delivery from ebay (if yours is stuffed)
#3 Posted : Monday, 20 June 2011 8:50:10 AM(UTC)
thanks Dave the radiator itself is pretty good, I should have realised it was plastic tank tho!
#4 Posted : Monday, 20 June 2011 5:46:45 PM(UTC)
These aftermarket radiators vary in quality considerably. Buy a known brand. Remember you only get what you pay for.
I've seen a few panel shops use these cheapies & come back with tank seam leaks in less than a month.
#5 Posted : Tuesday, 21 June 2011 5:42:48 AM(UTC)
yeah i agree terry, there damn cheap so i wasn't expecting much, been in the car for 3 months now, i'll guess i'll see how summer goes?
BTW, the brand of these radiators is nadrad
adam PERTH Offline
#6 Posted : Tuesday, 21 June 2011 9:04:34 PM(UTC)
adam PERTH
john there is a change in the fittings during VR / VS radiators for the auto cooler lines. I can't remember at the moment. i think VS series 2 up had the improved design....have a look, you will see what i mean...make sure its same for same...
#7 Posted : Tuesday, 21 June 2011 9:25:12 PM(UTC)
That's correct, VS series 2 onwards have the threaded flare fitting, where the old style just use a hose clamp.
