satanic customs Offline
#1 Posted : Thursday, 7 July 2011 10:52:47 PM(UTC)
satanic customs
i've just detected a bit of a miss with the V6 VY, starts and idles fine but when at speed (100) and i point it at a slight hill, not enough to drop back a gear (auto) it seems to miss/shudder. it's only there at that point. hard acceleration no probs, coasting no probs. i initially though possibly uni joints because it feels a bit like backlash, but thinking more about it i doubt it. any ideas?
thanks in advance
petaus Offline
#2 Posted : Thursday, 7 July 2011 11:07:47 PM(UTC)
petaus
change the plugs and leads, very common when the torque convertor clutch is applied and start to increase a load i.e up hill it will begin to miss.
80569K Offline
#3 Posted : Friday, 8 July 2011 7:04:48 AM(UTC)
80569K
Had a similar problem with a VX V6, sitting on 100kph it would drop 200 revs every 20 seconds or so, Dr T suggested Pete's remedy and it worked fine for me.
Edited by user Friday, 8 July 2011 7:05:33 AM(UTC)  | Reason: Not specified
bullitljv8 Offline
#4 Posted : Saturday, 9 July 2011 12:57:04 AM(UTC)
bullitljv8
definately leads or plugs i would say more leads but do the plugs aswell....
#5 Posted : Saturday, 9 July 2011 6:10:46 AM(UTC)
check the leads to see if there's any white powdery stuff on them, if so there stuffed
but it defiantly sounds like leads
#6 Posted : Monday, 11 July 2011 9:44:31 AM(UTC)
satanic customs
You blokes were spot on, replaced leads and plugs no more probs. Seems to start easier too. Super cheap had 20% storewide yesterday, with the money saved I shouted it a new accessory belt as well, the one on it was a bit daggy. Aren't they easy to fit? Took a couple of minutes!
Thanks heaps
#7 Posted : Wednesday, 20 July 2011 8:51:43 PM(UTC)
satanic customs
ok, after about 1500km the problem has returned. the plugs and leads when renewed DID solve the problem but it's back. same symptoms. i used bosch items as replacements, is one defective or have i got bigger problems like a coil or something? could the plug gap be the issue?
cheers fellas
BIGCAV Offline
#8 Posted : Wednesday, 20 July 2011 9:02:48 PM(UTC)
BIGCAV
is it on gas etc?
#9 Posted : Wednesday, 20 July 2011 9:38:31 PM(UTC)
satanic customs
no mate not on gas. bog stock v6 auto with no mods
BIGCAV Offline
#10 Posted : Wednesday, 20 July 2011 10:11:02 PM(UTC)
BIGCAV
you mentioned the plug gap, what is it? from memory should be 1.5mm
petaus Offline
#11 Posted : Wednesday, 20 July 2011 11:17:32 PM(UTC)
petaus
dont you hate that, i use genuine leads the set i fitted had made in china on the bag god bless holden lol, they fit well lenght wise yet never had a problem with them and there cheap, i spose you have a lead problem or maybe a coil now playing up, as soon as you fix a weak link in the system the next weak thing plays up, have a look on the leads for any signs of arching???
pete.
#12 Posted : Thursday, 21 July 2011 12:35:32 AM(UTC)
satanic customs
believe it or not the bosch leads bought at super cheap are australian made- i was surprised at that. i'll look for something obvious if not i guess holden will have to look at it. plug gap is 1.3mm
thanks pete, cav
This page was generated in 0.192 seconds.
