adam PERTH Offline
#1 Posted : Saturday, 9 July 2011 12:54:33 AM(UTC)
adam PERTH
its that time of year,...
i went to charge a calcium hybrid battery in a commodore with my supercheap $50 calibre charger which has been excellent for the last 5 years and it blew it up.
the fine print on the calibre said lead batteries only.
whats the go here?? how do you charge a calcium battery then?
lildog Offline
#2 Posted : Saturday, 9 July 2011 2:22:04 AM(UTC)
lildog
There are specific chargers for calcium or hybrid/gel batteries. The charger will need to push high amperage in its initial stage of charging. I've had success with a Projecta charger and start the charging with the discharged battery and a known good battery being charged together, then after 1 hour remove the good battery. Hope this helps
adam PERTH Offline
#3 Posted : Monday, 11 July 2011 10:29:56 AM(UTC)
adam PERTH
thanks.
looks like for now i have to use the ABC's bush mechanics method and put the battery in the embers of a fire and get it to work that way!
Oily Offline
#4 Posted : Wednesday, 13 July 2011 8:57:03 AM(UTC)
Oily
"looks like for now i have to use the ABC's bush mechanics method and put the battery in the embers of a fire"
AH what a crack up that show was, covered every thing from your flat battery to makeing a new clutch lining out of tree roots. But the best had to be the guy sucking the fuel out of the line at the pump on that old holden and squirting it out the gap in his teeth over into the carb.
peter_flane Offline
#5 Posted : Wednesday, 13 July 2011 9:26:25 AM(UTC)
peter_flane
Broken suspension using a log as a slide was good
#6 Posted : Wednesday, 13 July 2011 10:28:30 AM(UTC)
you can replace the diodes in those chargers for about 3 bucks. takes no more than 20 minutes. I have done mine a few times, I buy old chargers that have burnt out get them cheap and just replace the diode.
hqgts Offline
#7 Posted : Thursday, 14 July 2011 4:42:00 AM(UTC)
hqgts
you need a multi stage charger.... a gel battery will die after 12 months if charged with a standard charger
Al
adam PERTH Offline
#8 Posted : Monday, 18 July 2011 3:31:37 AM(UTC)
adam PERTH
ok thanks. the charger i blew up said it was a 2 stage charger, ,80% it went into power mode, and above 80% charge, it went into float mode....
is this the type you mean?
This page was generated in 0.115 seconds.
