gwumpy Offline
#1 Posted : Monday, 11 July 2011 9:11:48 AM(UTC)
gwumpy
I am looking to convert my HG 186, 3 speed column manual to either a powerglide or trimatic with column shift. I am looking for advice on which box to go for. The ute is only a weekender and does not see alot of kms. I will also need a column, linkages, pedal assy. Cheers
satanic customs Offline
#2 Posted : Monday, 11 July 2011 9:52:07 AM(UTC)
satanic customs
I'd go for the trimatic, you cant have too many gears I reckon. Easier to obtain too. Ive got a 6 cyl tri avail, near ipswich QLD. Shouldnt have too much trouble getting the rest
adam PERTH Offline
#3 Posted : Monday, 11 July 2011 10:23:05 AM(UTC)
adam PERTH
put an impala side shift on the 3 sp all synchro, oh yeeh!
#4 Posted : Monday, 11 July 2011 10:51:28 AM(UTC)
satanic customs
Utility8 Offline
#5 Posted : Monday, 11 July 2011 9:33:26 PM(UTC)
Utility8
Yep, go Trimatic, particularly as you have a six cyl.
Column setup, with a RH side selector shaft box, should be a reasonably simple conversion from manual to auto.
Trimatic to suit a six can have some upgrades done to make them stronger & change well.
I see you're in Vic, I can recommend a guy in the Northern suburbs that I have had build a number of boxes including a Trimatic for a VK inj 6 cyl.
Edited by user Monday, 11 July 2011 9:33:58 PM(UTC)  | Reason: Not specified
utility8
1970ht Offline
#6 Posted : Tuesday, 12 July 2011 5:10:29 AM(UTC)
1970ht
My 186 ht prem has a powerglide and is the most reliable and toughest gearbox evermade . They have a preety good torque convertor that acts like a third gear anyway , just my 2 cents worth lol .
dirty davo Offline
#7 Posted : Tuesday, 12 July 2011 9:04:05 AM(UTC)
dirty davo
torqe coverter is same for traumatic as powerglide !!!!
i have a recent reco powerglide here for 6cyl thats 2yrs old an only done 1500miles for $475
regards DD
www.bellarineclasasicautos.com.au
dirty davo Offline
#8 Posted : Tuesday, 12 July 2011 9:14:44 AM(UTC)
dirty davo
regards DD
furtheremore , trimatic will never take abbuse like a trusty ole powerglide will period!!!!! but recoed, a trimatic (investing cuppla hundred bux more)can take anything., & with an extra gear, is th way ta go
gwumpy Offline
#9 Posted : Tuesday, 12 July 2011 9:23:22 AM(UTC)
gwumpy
regards DD
Does it come with a convertor?
Do you have all the other parts i will need?
Regards
dirty davo Offline
#10 Posted : Tuesday, 12 July 2011 5:44:00 PM(UTC)
dirty davo
regards DD
Regards
yes, complete with torque convertor, flex plate spiggot & dust cover
& yes i can supply column, linkages & pedal box assy,tranny lines, loom mods,& dash illumination parts. auto radiator
regards DD 0412109239
This page was generated in 0.343 seconds.
