Mick G Offline
#1 Posted : Saturday, 23 July 2011 6:52:12 PM(UTC)
Mick G
Hello,I have a 350 engine with the engine no QU40542 K0201H.Was this motor fitted to an Aussie car as the last part of the of the number is similar to the 307 in my HK Premier.Cheers and thanks,Mick G
Water makes it's own sauce
KeithA Offline
#2 Posted : Saturday, 23 July 2011 8:54:14 PM(UTC)
KeithA
The QU prefix, if I'm correct, say's it out of a HQ Monaro 350. The HQ Statesman came with a 11QU prefix in the 350.
#3 Posted : Sunday, 24 July 2011 12:20:15 AM(UTC)
It is from a Dandenong built HQ GTS350 coupe or LS with L30 engine option. I'll see if I can get more info on it, like if the original car is still around and looking for its engine!
KeithA Offline
#4 Posted : Sunday, 24 July 2011 6:00:09 AM(UTC)
KeithA
Hey HK1837, which part of the number tells you it's a coupe or LS? Also the L30 (which I assume is stamped on the tags) means it had the 350?
#5 Posted : Sunday, 24 July 2011 7:06:40 AM(UTC)
It is an early number from Dandenong hence it has to be a coupe or LS as apart from statesman these were the only cars to get 350 (it has no 11 prefix so is not Statesman). It could at the outside be from one of the other handful of Dandenong cars built with 350's which I think there were 4 x Premier wagons and 2 x utes, however I think the number is a little early for these and it looks way too early to be from an XW8 Kingswood. We'll see soon enough where it belongs.
#6 Posted : Monday, 25 July 2011 11:18:35 PM(UTC)
Apparantly there were a lot less Dandenong built HQ Statesmans with L30 engine than I thought, so this engine is later than I expected. It is probably from a car from the first half of 1973, and it is a manual engine so MOST likely from a 4 door GTS as bugger all 1973 build 4 door Dandenong 350 powered GTS coupes were made. Could still be a coupe engine, but probably not. So, does anyone know of a 1973 HQ GTS350 manual sedan or coupe missing its engine? This will be a near one off opportunity to get in touch with Mick ^^^above and buy it if he'll sell it!
D. A. Barnes Offline
#7 Posted : Tuesday, 26 July 2011 2:58:34 AM(UTC)
D. A. Barnes
You're spot on in this being a manual engine. The code is the same as mine. The Monaro guru would be able to tell you which car it belongs to (or did belong to). If it was a Sydney engine I would buy it for a spare.
#8 Posted : Tuesday, 26 July 2011 4:12:38 AM(UTC)
It is from a 350 manual XW8 Kingswood. So anyone know of a Dandenong HQ GTS350 4 door manual with PSN J37029x speak up!
#9 Posted : Tuesday, 26 July 2011 4:22:13 AM(UTC)
that car would be long long gone..
#10 Posted : Tuesday, 26 July 2011 6:01:02 AM(UTC)
I imagine so too, but there are a fair few 350 cars around without their engines. You never know!
Mick G Offline
#11 Posted : Thursday, 28 July 2011 2:12:43 AM(UTC)
Mick G
Thanks heaps boyz.It is in my HZ tonner,getting put on straight gas as we speak.Any more research would be much appreciated.Cheers,Mick G.
This page was generated in 0.092 seconds.
