On the legs of the subframe there are a series of holes which the crossmember bolts to and i cant remember/didnt take notice what ones they went through when i took it off. I have a trimatic gearbox on a red 202 and i was just wondering what holes does it go through to bolt it in place before i put the engine and box it, or do i have it round the wrong way, engine + box then crossmember?
I think you've answered your own question.
Put the engine & trans in & then use whichever holes line up.
Dr Terry |
Real hard to get the transmission over the crossmember if its on first. You'll scratch everything in the process.
Do as per doc Terry |
Stepping stone or stumbling block...your choice |
I have to many questions and start far too many posts... haha im sure i keep some knowledgeable people entertained with my noob questions!
traumatic as well as 3spd synchro (whether its V8 or 6cyl) bolt up to the rearest hole if that makes sense!! regards DD www.bellarineclassicautos.com.au
A Noob question sure beats the hassal (and cost)of a noob mistake. Besides which .... how do you learn? |
