toddyg Offline
#1 Posted : Sunday, 25 September 2011 5:41:44 AM(UTC)
toddyg
hi,have a oil presser problem(have checked gauge and fitted new oil pump)have been told oil pick up may be loose.)any helpful info would be great.for eg can i jack up engine high enough to get sump off or do i need engine crane,any tips on what i have to undo and where best to jack engine up ect. cheers todd
pezwa83 Offline
#2 Posted : Monday, 26 September 2011 1:44:10 AM(UTC)
pezwa83
Hi,
I thought the oil pump on a 308 is inside the sump? maybe im wrong?
KeithA Offline
#3 Posted : Monday, 26 September 2011 4:14:21 AM(UTC)
KeithA
Oil pump on a 308 is at the front, bottom of the engine. Can be removed without removal of the sump. toddyg is checking the oil pick up which does require the removal of the sump, hence his question.
Bruvpig Offline
#4 Posted : Monday, 26 September 2011 4:17:07 AM(UTC)
Bruvpig
Had this happen to me a few years back. $1.63 gasket, and a whole lot of headache.
You will need to get access to the pickup bolts on the bottom of the block inside the sump, so you will have to have enough clearance from the crossmembers and steering (depending on what model) as well as removing the trans inspection/clutch cover.
There will be next to no clearance around anything if you just drop the sump, so you will have to lift the engine up to get clearance.
Then there is the re-fitting of the gaskets for the sump, best to have lots of space to work to get it right or risk a messy everywhere-you-park, as well as defects
Sorry
Edited by user Monday, 26 September 2011 4:18:39 AM(UTC)  | Reason: Not specified
Stepping stone or stumbling block...your choice
toddyg Offline
#5 Posted : Monday, 26 September 2011 8:46:21 PM(UTC)
toddyg
thx bruvpig for reply,sounds like a prick of a job,i think get someone more qualified to do the job.once again thanks for info its great to get some good feed back from someone that had same problem.
cheers todd
playwme Offline
#6 Posted : Tuesday, 27 September 2011 4:02:00 AM(UTC)
playwme
I pulled the sump off my HZ once with it still in the car. Now I just save time and whip the engine out. It was a PITA and trying to get the gaskets right is hard enough when you can actually see what you're doing, let alone lying on your back getting little grains of dirt in your eyes.
This page was generated in 0.094 seconds.
