kell1234 Offline
#1 Posted : Saturday, 24 December 2011 12:28:33 AM(UTC)
kell1234
hey everyone
i have a ve ss ute lots of work done and im experiencing a hissing noise when i accelerate the noise sounds like its coming from around the bottom of the engine bay. im not sure wether its just the belts maiking the noise or a leaking seal but im not leaking any fluids
my mods include
lumpy cam
extractors
3 inch exhaust with high flow cats
moral lifters
rocker arms
performance valve springs
russo's custom OTR air intake
exceedy clutch
minispool diff 4:11 ratio
can anyone give me some advice weather this is a normal sound or the could be something wrong
playwme Offline
#2 Posted : Saturday, 24 December 2011 10:39:44 AM(UTC)
playwme
Yep, it could be normal or it could be something wrong. High flow air filters tend to make a bit of a hissing/sucking noise when you crack the throttle open. Otherwise check for loose vacuum hoses or try to pinpoint the source by ear.
Utility8 Offline
#3 Posted : Saturday, 24 December 2011 6:32:28 PM(UTC)
Utility8
Don't laugh while you are doing this, but grab a length of garden hose, maybe 1m long.
Stick one end to your ear & then point the other end near where the noise is coming from using it like a stethascope.
It's quite interesting what noises, good & bad, that you can isolate & pin point this way.
Oh, & another thing, sort any issues you may or may not have with the car before posting in the For Sale section on the same forum at the same time.
utility8
#4 Posted : Saturday, 24 December 2011 6:40:45 PM(UTC)
maybe you have a snake in your cab and squash his tail when you put your foot down! LOL
