Fastlane
Holden Forums
Holden Technical Talk
Hk ht hg v8 wagon original tyre size
Hi, Wanting to know the original tyre size for a v8 wagon. Particulary the hg. Online research suggests 7.35 x 14" on a 5" rim. Is this correct and standard for all v8 wagons? Does that size equate to a 195/70/14 ?
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
It depends upon the wagon. Standard tyre for HG V8 Belmont and Kingswood wagon was 7.35 x 14 4 cross ply, with L (Rayon) performance rating on 5" rims. Standard tyre on HG V8 Premier wagon was basically the same thing but with white sidewall. There were a lot of tyre options too, including D70 4 cross ply hi performance on N66 rims. Try here: http://www.exploroz.com/...icle/Tyres/SizeCalc.aspxIt says 7.35 x 14 is equivalent to a 185/100/14 |
Thanks for the reply HK1837, But if sedans came out with 6.95 inch tyres (185/75/14)then 7.35 would be 195?
No idea, you'd have to look up on a tyre size converter chart. |
Fastlane
Holden Forums
