Hi there just wondering if anyone on here knows of easy straight swaps for interior items, so basically I have a 1995 XG ute and I want to change pretty much all the interior if I can but I don't want to be messing around with anything too much as I just want to remove current interior and then put new things in.
so does anyone know if there are different dashes, clusters, door trims, center consoles or seats for an easy swap into a 1995 XG manual ute.
Easiest thing to do is track down the front half of an XF Fairmont Ghia interior or even a ZL Fairlane or the equivalent LTD.
by front half do you mean full cab or just interior because I don't really want to change the exterior of the ute.
I mean the front half of the interior as obviously you don't need the rear seat or door trims. Direct fitment into a ute or van.
Jim... |
