I have just put a VR 5Lt with a VP TH700 into my van, with a VR auto loom and upgraded ECU from Castle Auto (someones unfinished project). Motors going from key. But I have been told that because the auto is hydrolic not electronic the ECU will play up with the motor. Dose any one know of a way to get around this with out getting a VR box or a manual Loom and ECU.
Yes.
use a VSS from Injection Perfection in PErth. otherwise ur motor will not reach full potential b4 the ECU cuts it out.
Ed
Did you make the loom up your self or use a loom from castle auto. and have you got any photos on the computer of your conversion coz if you dont mind i would like to take a look at it and see how you did it
