2 Pages<12
#21 Posted : Wednesday, 22 September 2010 6:17:00 AM(UTC)
I'm pretty sure that is a VR manual ECU and a VN Memcal. Not sure if this works OK?
aidanhq Offline
#22 Posted : Wednesday, 22 September 2010 6:40:29 AM(UTC)
aidanhq
Yes I need to find out if it works.
VR!!!!! thid would explain no pulse/spark. Bastard told me it was 100% a VN ECM.
93-95 VR Commodore 3.8 V6 (man) GMH 16183082/16206305
93-95 VR Comm/Stat 5.0 v8 (man) GMH 16183082/16206305
93-95 VR Comm/Stat V8 180kw(man) GMH 16183082/16206305
93-95 VR Utility 3.8 V6 (man) GMH 16183082/16206305 93-95 VR Utility 5.0 V8 (man) GMH 16183082/16206305
95-98 VS Commodore 3.8 v6 (man) GMH 16183082/16206305
95-98 VS Comm/Stat 5.0 High Perf(man)GMH 16183082/16206305
95-98 VS Utility 3.8 V6 (man) GMH 16183082/16206305
95-98 VS Utility 5.0 V8 (man) GMH 16183082/16206305
98- VT Commodore 3.8 V6 (man) GMH 16183082/1620630
#23 Posted : Wednesday, 22 September 2010 7:00:58 AM(UTC)
It may not be the issue. I think you may still be able to use an 082 ECU with a VN memcal OK. The major difference is the serial comms rate. Send Commodorenut (Mick) a PM and he may be able to help you on this.
Holdenute Offline
#24 Posted : Wednesday, 22 September 2010 7:58:57 PM(UTC)
Holdenute
The VN/VP didn't have security, so potentially the VR unit is conflicting with the VN memcal?????
Never late in a V8
Never late in a V8
aidanhq Offline
#25 Posted : Wednesday, 22 September 2010 8:32:46 PM(UTC)
aidanhq
I sent a email to commodorenut so Ill wait for a reply.
cheers fellas
Are there any workshop manuals that can be posted in regards to ECM'S and also diagnosis flowcharts with my lack of pulse/spark? As a reference?
Im making a conversion document with all my problems and answers.
aidanhq Offline
#26 Posted : Wednesday, 22 September 2010 11:33:38 PM(UTC)
aidanhq
Is there a difference between the wiring of the hall effect sensor plug on VN and VR??
Does the red wire in the hall effect + line up with the black/white wire on the plug??
aidanhq Offline
#27 Posted : Thursday, 23 September 2010 8:42:34 AM(UTC)
aidanhq
Ignition module is earthed to body.
I followed this --
Switch ignition ON and probe each terminal of an injector wiring connector with a test lamp to earth.
If test lamp lights when the probe contacts the light blue wire terminal,check the wiring harness for shorts to voltage between the
injector wiring connectors and the control unit wiring connector terminals D15 and D16.
If the test lamp does not light when the probe contacts the red wire terminal,a fault in the EFI relay or circuit is indicated.
If test lamp lights when the probe contacts the red wire terminal,proceed as follows...
Switch ignition OFF connect the injector wiring connectors.
Switch ignition ON and backprobe the control unit wiring connector terminals D15 and D16 with a test lamp to earth.
The test lamp should light when the probe contacts each terminal.
If the test lamp does not light,check the wiring harness for continuity between the injector wiring connectors and the control unit
wiring connector terminals D15 and D16...repair or renew the wiring harness as necessary.
I have power at both sides of the injectors (blue/red) when ignition is on. I don't have power at D15 or D16 (blue wires on ECM).. Someone has soldered a small white plug into these wires?? Check out the pic. Should I run a new D15 wire to injectors? And a new D16 wire to injectors? Does it matter which ones they go to?
http://s847.photobucket....rent=injector-wiring.jpg
Edited by user Thursday, 23 September 2010 10:31:47 AM(UTC)  | Reason: Not specified
aidanhq Offline
#28 Posted : Saturday, 2 October 2010 7:13:23 AM(UTC)
aidanhq
After removing the plug and gaining power at D15 and D16.
I fixed the ignition/cranking power situation and now have 12v while cranking and ignition.. Well it's 10ish while cranking.
So far NO DEAL..
Still don't have spark or pulse!!.
Checked for codes got one flash followed by 2 flashes. -- 12 No spark pulses at CPU or else good system, no codes
Can someone explain how to test the spark pulse situation at the ECM ?? Because I corrected the injectors at the ECM side when I reconnected the blue wires.
I will replace the 4 wires going from ignition module to ECU.
Anyone?
2 Pages<12
