dose anyone have a uni joint or the retainer caps to suit this type of yoke it is out of my ej and none of the other bajo yokes i have are the same cheers Rhys
Joined: 3/2/2005(UTC) Posts: 488 Thanks: 3 times Was thanked: 7 time(s) in 7 post(s)
Ruys,they are the same for FX-FJ.
gees that old now wear do i get one of them from
I believe all Grey motored Holdens used that type of rear uni, up to & including EJ.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
i may be able to help with one. i will add it to the list of things to do next week.
Tuning for Holley carbs in Perth? PM me. |
cheers rare spares do sell them but as normal they want alot of money for them
Do you have the option of putting one of your other diff centres in? That will allow you to use standard uni joints! What ratio is the one you have out there now, and what other ratio's do you have? What motor are you running? If it is old or rare - Cut it! http://www.ehlimo.com.au/ |
nahboth the other banjo's are well and truely stuffed and the ratio in this one is 3.9:1 (or near enough)
Yep, should be 3.89 for any Grey Motor diff.
and its not going in my car iam just trying to get my mates eh up and going again
rhuys. I have 3 new old stock ones (all the same), one stamped 3.36, one stamped 3.55, and one with no stamping. Looking at $65 each. email sent. AL. Edited by user Sunday, September 19, 2010 9:01:50 AM(UTC)
| Reason: Not specified
sounds good what does that include can you post a pic cheers Rhys
Rhys,I may have miss read your post, the yokes I have are the same as the picture you posted. AL.
yes iam after the uni joint that bolts to it
Any good spare parts dealer should have them......try a diff repairer? al
i can get the uni thats easy but not the mount cups the only place i can find is rare spares and they want $150
