Just need some measurements for welding in some consul mounts in my HQ One Tonner . Any ideas Thanks Matt
Matt
Find a car and measure. It will make it heaps easier for you.
Matt,as above or put everything in its place including gear shifter/tbar and sit in comfortably and go from there,if its a one tonner that"ll be ok,I wouldnt do this on a monaro,no offense.I did that in my HQ panelvan with a hz console.
Jim in Adelaide.. |
Jim in Adelaide.. |
Hi Matt,
If it is an auto - only mark the holes for the 3 mounting screws once the console is in place and the orange t-bar indicator is inline with whatever position the shifter is in. Otherwise it will be out of line and p$*% you off.
