any one knows the name of my interior code number 18g7-38n, any can one get it in adelaide,
38N pictures can be found here http://gallery.oldholden...+Codes/HQ/38/Statesman/
Sorry no help on the supply side of things though. Cheers Paul.
38N is Black Vinyl & Devereaux Cloth seat facings in an HQ Statesman DeVille.
The 18G7 is probably 1867 (it should be 4 numerals, no letters) , Juniper Metallic exterior paint. If your paint number is 15334 that will confirm it.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
New glasses required !! 30N is Black, 38N is Doeskin. Silly mistake on my part. Dr Terry _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
