#1 Posted : Tuesday, 18 May 2004 10:31:10 PM(UTC)
With the conversion into a hz what computer controls the speedo, central locking etc does the engine computer do that as well or is there a seperate car computer?
#2 Posted : Tuesday, 18 May 2004 10:44:15 PM(UTC)
In a VT-VY the speed signal is fed to the Engine Computer (ECU), and then processed & fed to the electronic speedo. Thus you would need to fit some form of electronic speedo to your HZ. Holden can calibrate the speedo for you using a Tech2 diagnosti
#3 Posted : Tuesday, 18 May 2004 11:31:13 PM(UTC)
Id use a Delco 808 from Camira, Astra VN without BCM.
#4 Posted : Wednesday, 19 May 2004 12:38:06 AM(UTC)
so do you think i can get away with using a cable speedo somehow? or does the ecu NEED the speedo data? what other signals does the ecu take that aren't supplied by the engine that I would have to consider. for example if i used a TH400 and a 9" di
#5 Posted : Wednesday, 19 May 2004 12:40:29 AM(UTC)
Whats the difference between the delco 808 and the gen III equivalent? although i don't like the word camira in there!!!
#6 Posted : Wednesday, 19 May 2004 12:54:28 AM(UTC)
Dan,
I have a TH400 and 9 inch in my EFi conversion... I use a VSS from the Th400 into the ECU. I dont know exact pulse rate off hand. anyway this helps with IAC.
U can plug a speedo cable into the back of this if desired.
Kalmaker site ha
#7 Posted : Thursday, 20 May 2004 12:50:33 AM(UTC)
hey ed, I have no idea what you mean when you abbreviate stuff so can you explain vss and iac, plus what conversion do you have?
#8 Posted : Thursday, 20 May 2004 2:37:17 AM(UTC)
VSS = Vehcile speed sensor
IAC = Idle air control
I have a 308 red with Vn heads, harrop d/plane and 4bbl throttle body with commodore fuel rails.
Delco 808
TH400 trans
9 inch
in FE Holden.
#9 Posted : Thursday, 20 May 2004 3:46:07 AM(UTC)
bugger me, now that is a different conversion!!!
#10 Posted : Thursday, 20 May 2004 9:25:48 AM(UTC)
I reckon the FCis the nicest Holden built, not too big, nice shape, needs a bit of modding but still love it. I want a wagon.
#11 Posted : Thursday, 20 May 2004 6:39:09 PM(UTC)
i agree totally John (FE though)
ive modded the body and its a wagon!
Ed
#12 Posted : Saturday, 22 May 2004 9:12:56 PM(UTC)
MMM where to start..Daniel do you want Gen 3..which is chev or Delco which is Holden conversion.Both original computers are programmable by the right person.You can use vehicle speed sensor on both,But you either have to use a cable splitter to retain mec
