the trouble i have seen with the WB is the chassis rails arn't strong enough and they twist making it impossiable to get the correct wheel alignment. check and see if you have any shims left in the upper control arm if not the lower ball joint needs moving in ,or the upper joint out. Not really a back yard job. I dont know what these kits are maybe they are your answer. good luck... Darrin
