Looking everywhere to see if I can ID two Borg Warner Single Rail gearboxes
Does anyone know where to find a list of codes ?
I have an 84 DA 7003 BA 0503 038
and a 76 DA 7003 AA 05 03 009
Going to assume the 84 means the build year as it has an electronic speedo drive and wire fitted
Any help would be appreciated |
AR |
yeah your correct, 84 would be xf 76 would be xc
xd/e/f 0503 carby 1st-3.43 2nd-1.99 3rd-1.43 4th-1.00 rev-3.29 0503 efi 1st-3.50 2nd-1.99 3rd-1.32 4th-1.00 rev-3.47 0506 1st-3.47 2nd-1.96 3rd-1.26 4th-1.00 rev-3.37 0507 5spe 1st-3.47 2nd-1.96 3rd-1.26 4th-1.00 5th-0.79 rev-3.37
xa/b/c 0503-009 (4.1/4.9) 1st-3.06 2nd-1.84 3rd-1.32 4th-1.00 0503-008 (5.8) 1st-2.46 2nd-1.78 3rd-1.27 4th-1.00
AR |
Thats Great thanks
Would you know the difference between the 009 302 and 008 351 is it just the gear ratios matched to the different diff combos at the time or is the 008 stronger with bigger bearings ETC |
AR |
its really stretching my memory so please dont take it as gospil but i always thought they were just as strong as each other, it was just gearing that was different
Thanks I will get hold of a gearbox reco place and see what they have to say . When I find out I will post the results
It would seem logical that all boxes bearings and syncros where the same and only the ratios varied depending on the motor and final drive ratios combination |
AR |
Joined: 12/02/2016(UTC) Posts: 1 ![Australia Australia]() Location: geelong
hi l have an 84 DA 7003 BA 0503 038 gearbox
how do l no witch gear ratio l have in gearbox
Thanks: 1 times Was thanked: 240 time(s) in 214 post(s)
The ratios that you've quoted for XA/B/C I think might only apply to XC. The XB Factory workshop manual quotes box part no. 0503-003 with ratios of 1st-2.82, 2nd-1.84, 3rd-1.32 & 4th-1.00 Dr Terry |
