Fastlane
Holden Forums
Holden Technical Talk
Urgent Help Needed- Bonnet Release Broken
Well Its a sign, time to fix a problem
First off I pulled the bonnet release from inside under dash and bastard of a thing pulled straight out
Now Im stuck, how the hell do I get bonnet open firstly to fix cable, to I can not take grill off with out opening bonnet so how does one get access
What a bloody drama
Once I solve this then I need to fix problem that I was opening bonnet for hahaha
Oh you gotta love old Holdens
Thanks HZ |
Living the Dream |
Joined: 29/07/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
A long screw driver through the grill works on HQ's . . . You'll need a torch. The part that gets pulled by the cable, you can usually push it sideways with something. |
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
if rig pig suggestion doesnt work try going up from under the bar there should be a gap you should be able to get to the catch from there and lever the catch from there
i just stick a long screw diver through the grill and push the catch across
could you grab the left over end of the cable with pliers and pull it?
in a HJ HX HZ the grill holes can be damaged easily using a driver, the best method is from inder neath the bumper, having long thin arms help... |
HOLDEN The Great Way to Move |
Fastlane
Holden Forums
