HZ_Premier Offline
#1 Posted : Tuesday, March 22, 2011 4:24:59 AM(UTC)
HZ_Premier
Well Its a sign, time to fix a problem
First off I pulled the bonnet release from inside under dash and bastard of a thing pulled straight out
Now Im stuck, how the hell do I get bonnet open firstly to fix cable, to I can not take grill off with out opening bonnet so how does one get access
What a bloody drama
Once I solve this then I need to fix problem that I was opening bonnet for hahaha
Oh you gotta love old Holdens
HZ
Living the Dream
#2 Posted : Tuesday, March 22, 2011 5:03:36 AM(UTC)
A long screw driver through the grill works on HQ's . . . You'll need a torch.
The part that gets pulled by the cable, you can usually push it sideways with something.
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
275monaro Offline
#3 Posted : Tuesday, March 22, 2011 5:51:32 AM(UTC)
275monaro
if rig pig suggestion doesnt work try going up from under the bar there should be a gap you should be able to get to the catch from there and lever the catch from there
#4 Posted : Tuesday, March 22, 2011 6:18:42 AM(UTC)
i just stick a long screw diver through the grill and push the catch across
could you grab the left over end of the cable with pliers and pull it?
#5 Posted : Tuesday, March 22, 2011 6:56:28 AM(UTC)
in a HJ HX HZ the grill holes can be damaged easily using a driver, the best method is from inder neath the bumper, having long thin arms help...
This page was generated in 0.132 seconds.
