Squeak327 Offline
#1 Posted : Wednesday, 13 April 2011 12:34:30 AM(UTC)
Squeak327
Amongst a bunch of parts I acquired recently is a bellhousing which has "HOLDEN 7437548" cast on it. It is a holden V8 bolt pattern and is the removable type like what is found on 6cyl powerglides.
From what I can gather, this would only have been fitted to a 253 or 308 in a HT
or
possibly on export model HGs with a holden V8 motor and powerglide transmission - if indeed there ever were any such vehicles
Can anyone confirm?
dirty davo Offline
#2 Posted : Wednesday, 13 April 2011 1:06:27 AM(UTC)
dirty davo
or
Can anyone confirm?
yes thats for HT holden V8 p/glide only. so it was std for all HT broughams & monaros etc. sth african HT would of used em also.
Is th bellhousing for sale?? i have a p/glide here with cracked b/h & would prefer yors rather than get mine welded.
regards dave 0412109239
Squeak327 Offline
#3 Posted : Wednesday, 13 April 2011 2:25:50 AM(UTC)
Squeak327
OK thanks Dave.
I am willing to sell it or swap it.
I will send you a PM.
CrustyHK Offline
#4 Posted : Wednesday, 13 April 2011 6:47:50 AM(UTC)
CrustyHK
Is it right that the V8 powerglide has the speedo drive on the left and the 6 has it on the RHS?
At first glance any powerglide you spotted at a swap with a removable bellhousing you could easily miss as a 6cyl.
#5 Posted : Wednesday, 13 April 2011 7:01:57 AM(UTC)
Was thanked: 486 time(s) in 464 post(s)
Yes. 253/308 HT powerglide is a 6cyl box with V8 pump, speedo drive and extension housing. Bellhousings were special build for the application.
dirty davo Offline
#6 Posted : Thursday, 14 April 2011 3:25:42 AM(UTC)
dirty davo
[quote]Originally posted by CrustyHK
No, all 3 p/glides have speedo cable inlet on th right side.
[quote]
6cyl is smooth ext housing & chev & holden v8 one has webbing around bolt mounts. Although all are same length, th 6cyl one has th mount near yolk end (approx 3")& V8 ones are 4" more forward
regards davo
dirty davo Offline
#7 Posted : Thursday, 14 April 2011 3:34:48 AM(UTC)
dirty davo
OK thanks Dave.
no probs, i have sum good hk blue armrests here but lost your details. cld you PM me again or ring 0412109239
regards DD
This page was generated in 0.080 seconds.
