#1 Posted : Monday, 24 May 2004 5:16:59 AM(UTC)
i have a reco n308 in my wb ute. the engine number starts with qt, this tells me that the block at least is from an hq-hz. but im not sure if the heads are from same. will it make a difference if i buy spark plugs to suit a wb or hz??
#2 Posted : Monday, 24 May 2004 5:46:44 AM(UTC)
Yes,
The Red and Blue heads had different length spark plugs. What is the number on your manifold - this may tell you if you have red or blue head on your block. You could even check the plug you have in it already.
Any one know how to tell th
