vphunni Offline
#1 Posted : Monday, 23 May 2011 5:45:50 AM(UTC)
vphunni
Hey guys,
So, having a few problems! Just before I let go of the clutch the car rumbles a little or jolts. Once I let go it is fine. The car is a VP. I had the clutch and cluth bearing replaced at 230,000kms a little over a year ago. Im now at 280,000kms. A mate said it might just be the cable. What is wrong with my car? Or is it something totally different?
Any help would be greatly appreciated!
275monaro Offline
#2 Posted : Monday, 23 May 2011 5:53:56 AM(UTC)
275monaro
did you get the flywheel machined while you had the clutch out?
#3 Posted : Monday, 23 May 2011 6:02:15 AM(UTC)
sounds like the thrust bearing is giving up, if it is the thrust bearing and gets worse the engine will stall when you push the clutch in
vphunni Offline
#4 Posted : Monday, 23 May 2011 6:17:49 AM(UTC)
vphunni
Not sure if the flywheel was machined. Report from when clutch was replaced-
attended to rattle in clutch area, found clutch worn and clutch dampers worn-replaced. also replaced speedo transducer as broken.
If it helps when the clutch is released it squeeks the tiniest bit.
Cheers to those who have answered
#5 Posted : Monday, 23 May 2011 6:09:28 PM(UTC)
My parents had a VR manual and the clutch cable was always half seized up. Is it hard to push the pedal down? Try a new cable before you doing anything else.
If the flywheel wasnt machined and the clutch has been given a hard time then it will shudder when you let the clutch out.
