#1 Posted : Tuesday, 25 May 2004 12:21:40 AM(UTC)
Does anyone know how to stop the high pitch squealing from the front brakes? i tried disc brake quiet and stuff like that but it didn't work.
#2 Posted : Tuesday, 25 May 2004 1:55:28 AM(UTC)
Assuming your discs are machined OK and above the minimum thickness and your pads are servicable, I would say it would be the compound pad you're using. Pads with a high metal component seem to squeak more I've found, and have been known to wear the disc
#3 Posted : Wednesday, 26 May 2004 2:47:05 AM(UTC)
I have also had squealing and chirping it turned out the layers of lining on the brake pads had started to separate. and they were pretty new.
