hi all, can anyone help my fuzzy brain? hq one tonne ute
model, Hq 80160 ??? body, 8873-A trim, 1861-32A paint, 568-15351 eng, L20 box, m22
just under the wiper cowl it has a number stamped into body, 51921A can anyone tell me if this matches the tags? should it? i havent found chassis number yet. it has a 308, can i register this with id tags being a six? i think..
the tag on other side reads.. 8M601CL23889910 4/73 DHQ 26783A
Body ID plate. 80160 = 6-cyl Cab-Chassis (One-Tonner) (It is not a Ute !!) 8873-A = 8873rd body out of Adelaide 1861 = Willow paint (Green ??) 32A = Red vinyl interior 568-15351 = Dulux shade number for Willow L20 = 202 6-cyl engine M22 = Wide ratio 4-sp manual
VIN tag 8 = Holden M = Belmont or commercial 60 = Cab-Chassis (One-Tonner) 1 = Wrongly stamped L = 202 6-cyl engine C = 1973 model year (Built between 1/9/72 & 30/8/73) L2 = Adelaide plant 388991 = Sequential production serial number 0 = Should be Q (For HQ)
Compliance plate 4/73 = Compliance date DHQ26783A = Chassis number (This number should also appear on the chassis rail next to the steering box) D = 4th update of ADRs HQ = HQ series 26783A Serial number out of Adelaide
Dr Terry |
thanks Doc, legend... so what would the number stamped into body under windscreen? 51921A
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
That is an Elizabeth body number. They have no correlation to the numbers on the vehicle ID plates. |
ok doc, ta, just found chassis number, DHQ84797S
this does not match the id tags does it? will that cause me issues with reg? and what do these numbers tell you? thankyou by the way.. most helpful fella
and thanks HK, love the work
Green with red interior?????? Nice lol! Has it still got the red interior?
na man,,spuin ay,lol.. she just black now..
